I have a 73 65hp johnson I bought cheap. It had a cracked lower unit so I bought a 73 lower unit housing off of Ebay and swapped in the original parts. I put in new seals,o-rings and a new water pump impeller. Put the lower unit back on and it fired right up. I ran the motor in a large tub of water but I noticed there was no water coming out of the two holes on the back of the engine. I shut the motor off and fished around in the two holes with a piece of wire and pulled out some grass and a couple of crickets. I started the motor and just a small amount of water came out of the two holes. I remove the thermostat housing and thermostat and ran the motor and plenty of water came out so I know it's pumping water. My question is how much water should come out of the two holes? Thanks, Steve
