Re: 1970 Evinrude compression test?
They are close and it was cold so they should go to 130 hot, I wouldn't worry, certainly in the ball park.
Good points above, get your own compession gauge and only use it then you will know if there si a change it is the engine and not the gauge and alt of times a good decarb will raise your numbers.
