I have a 1979 Evinrude 140 (140943R) on my 15.5' Stott Craft Bass Boat. First, a little history on the boat/motor. I purchased the combo from an acquaintance who had a ice bag wrap around the foot while on the river and smoked the head. He had it bored .030" over, and a new impeller installed (according to the receipt he gave me). He had never put it in the water after having the work done. He had three kids back to back and had no time. I followed the break in procedure with a 25:1 mix. The boat has always been very hard to start, and would not idle unless fully warmed up. I have fought it for 5 years.
This past weekend I decided to get it running after sitting for 1.5 years. I noticed the starboard cylinders were over 200deg while the right side was still under 100. First thought was stuck thermostats. I pulled the t-stat cover and found nothing. Not good.
Next I ran the engine with the cover and hoses disconnected. I had a steady stream of water out of the port side and a erratic stream out of the starboard. Blown head gasket.
After pulling the heads I determined that the block was bored .030" like the previous owner claimed, But the 'mechanic', and I use that term loosely, Installed the starboard head gasket upside down.
Which you can see, toasted the head and pistons.
The port side had a little moisture in the bottom cylinder, but the head gasket seemed to be intact.
The heads were clean
Here is my plan, I have a '78 115 (115ETL78C) flat back that was given to me in good running condition but has a lot of corrosion on the foot (it sat in a freshwater boat slip most of it's life). It seems to have been properly maintained by a local marine shop. It's only owner was my friend's grandpa who has since passed away. The tale-tell mod where you tap each side of the block for water has been done. The port head gasket has been changed, while the starboard has never been opened.
After a compression check on the 115, I will pull the powerhead and put it on my 140. I will reuse the 140's carbs, reed blocks/reeds, exhaust manifold, power packs(both new), and coils (all are new). Are there any other items I should swap from the 140?
I have read that the '79 140's heads are high compression, but one of mine is fried so I will have to go with the 115 heads, will this create much difference? I will now be able to use regular pump gas instead of premium.
I will also be changing the impeller and getting the proper thermostats and pressure relief valves.
I plan to pull the heads on the 115, check all the water passages and change the tubes. I will go ahead and get a full powerhead gasket kit and change all the one I get to.
Is there anything I am missing, anything else I should look for?
