surfguitar7
- Jun 18, 2011
- 9
I have a 1992 johnson 40 hp that I just converted from vro to non vro by using a fuel pump and doing away with the old vro system. I am unable to get the primer bulb to stay hard and gas is coming out through the foot of the motor. I bought a sierra pump with lines and attatched it directly to the manifold. I blocked the old pulse line. Would gas be able to go through the pulse line or is possible that my carbs floats are not seated properly? I am going crazy trying to figure this out. I just rebuilt the carbs and changed everything out and I am not sure if the floats are set properly. Any help would be great. I have checked the lines and nothing seems to be leaking but a lot of gas is coming out.
