1984 warning horn melted New part fit? Wiring ?
edfishing2
0585992 is the original part number what new part numbers will fit? The old one was just round with tab coming off the side for the screw. The new ones look like they have wires attached while the old one just had tabs for flag connector. Voltage at the purple and tan wire was 2.8 volts and I disconnected the knife connections one at a time and found one temp switch leaking the 2.8 volts. FYI this temp switch was tested and tested good in hot water. Fuel restriction switch and other temp switch read 0.0 volts until grounded.
clanton
Re: 1984 warning horn melted New part fit? Wiring ?
The number I find from the BPR site is 0389263 which may convert to the number you have, dealer will have this info. The 0389263 number is plug and play.
clanton
I would guess the parts dept is selling you the wrong part.
