Stickler
- Feb 5, 2012
- 117
Hi everyone, iv recently had some free time and have been working on my 1971 4hp johnson(4W71D),what i have done so far is
-complete carb rebuild
-new head gasket
-new coils,points, and condensors
-new spark plug wires and boots as well as spark plugs(champion J8C)
-new fuel lines
When i did the initial timing i followed my manual procedure , checked for spark , alll checked out well so i re installed the fly wheel and set up the motor in my test tank.The reason i think it may be a timing issue is due to the fact that it takes up to 5 pulls usually to start it, idles nice,when i accelerate, the rpms dont increase like i believe they should be,(not a big difference)so i figured i needed to fine tune fuel delivery ,as it was not adjusted yet. I braught the motor to 3/4 throttle and turned the high speed needle in 1/8 of a turn and waited for engine to respond (RPMs should increase)but the motor doesnt react, so i kept turning the needle in and waiting ,no change, eventually it started to bogg out and i couldnt richen it quick enough to prevent it from stalling,when i tried to restart the motor it wouldnt go, i ran out of tinker time and had to leave at this point for the time being.
The throttle response , the hard starts,and lack of reaction to fuel adjustment is what leads me to believe it may be a timing issue,im not 100%, but it is somewhere to start, let me know if you think im on the right track or if there is something im overlooking , any suggestions are appreciated as always, Thanks again.
-Stickler
-new head gasket
-new fuel lines
-Stickler
