zepprocker
- Feb 29, 2012
- 12
Hey All,
This is my first post here. I recently bought a 1959 Dorsett Belmont Sport boat. Picked it up for 1700 with no fuel tank or battery. Everything else is clean, and the motor still has good compression. My question is, originally, these motors used pressurized fuel tanks. I'd like to get around that by using a conventional fuel tank and using an automotive fuel pump with a check valve to apply the correct amount of pressure. I assume I'd still have a return line to push out any fuel not used. I'm not quite sure what kind of pump I should look for, I think the automotive ones are in the 10 PSI range. Anyone know about this, or done anything like this? Also, suggestions on where to buy parts like this. I'm new to boating in general but have a decent mechanical know-how.
