I recently put this motor back into use after sitting for over a year. I replaced the lift pump because of the motor bogging down on take off but then it would run fine after having someone squeeze the primer bulb while moving. The issue I have now is that it fires right up but when I go to put it in gear it dies. The motor does seem to idle a little slower than usual. Could this be the problem? Or do I need to trouble shoot some other area? I did have the throttle and gear cables disconnected. I put them back the way they came off. Do I need to pssibly adjust the cables? If so is this something you do while the engine is running?
