Fowlhunter
- Feb 21, 2012
- 7
Hello all. This is my first post to the forum but I've been in boating since 1999 when I purchased my 1996 Evinrude 40 outboard with tiller (E40TEEDS). I had an issue with the motor going into S.L.O.W. mode and found the plastic nut that holds the temperature switch in the back of the head had come out and was melted. I replaced the temperature switch and changed out all of the parts for the thermostat assembly, I also replaced the spark plugs while I was at it. I recently read in my shop manual that the impeller should be changed once a year, true or false? I have never had it replaced and thought I needed to do it. I found a water pump repair kit and gearcase seal kit but my question is how do I go about changing it? I am very mechanical and feel I can perform the job rather than take it to a shop. Any help or suggestions would be great.
Thanks!
Thanks!
