I have a Johnson 1977 115hp 115ETL77 and after running good for the last two months it would not start. I just finish burning up 2 starters. I thought it would not turn over because the starter was bad. The 1st starter would no longer engage so, I replaced it. Put a new starter, a new solenoid and cleaned all connections. The starter would engaged but, it would not turn the flywheel. I kept cranking until the starter burned up. Now I think the starter was not the problem to begin with. In neutral the prop spins freely but, when I put in either forward or reverse it will not budge. Thursday I will pull the spark plugs to see if the flywheel/prop will move while in gear. Is there anything else I should check? I really hope I did not destroy my motor?.
Regards,
detox
Regards,
detox
