edfishing2
- Mar 6, 2011
- 144
Water is dripping from (hard to see while floating at the lake) starboard lower cylinder head area. It is dripping on the new cylinder head hose area. I have retorqued the heads once after break-in (book says 18-20 ft lbs.) Is it sometimes needed to tightened up to a higher torque? Say 22 or 25 to try to get this leak to stop? Or do I need to get new cylinder head gaskets? I will get it on muffs and run it tomorrow to see if while standing instead of floating I can pinpoint the leak.
