Hi, This is my first posting.
Anyway, I have a 60HP 1994 evenrude that has been sitting for about 2 yrs. zero gas in the carbs the entire two years. I had taken them apart to clean them and never got around to starting it up. Has a new fuel pump and filter. I start it with the engine sitting in a big trash can. It runs for about two to three minutes and dies. Like is is starving for fuel but i do not think this is the issue since it does not spit and sputter and then die. I see the stream of water as it is peeing and is is not hot to the touch. A part of me thinks it could be a temperature sensor? Not sure if it has one or not. Another note. If I give it a little throttle she will stay running. Any words of wisdom?
