ignition problems
bluesalty
Have a E60tlcuc 1987 60hp everude it had storm damage that damaged the head and coils on the engine, the coils that were on the motor were 582508-24DM-OA I bought two coils off ebay that I was told wold work, they were 58250:cool:A-06T27 will these work the same or they different, I have installed them but I can't seem to get the engine to fire over. I have pulled the plugs and trun the engine over and am getting blue fire coming out the plugs, but i still will not fire off. can the plugs fire and the power pack be bad, if not what else could it be ?
boobie
Re: ignition problems
Plugs don't mean anything. The spark should jump a 7/16 " open air gap on a spark tester. You could also have some compression or fuel probs.
boobie
You should stick to one post as you may get better answers.
