I have cracked float chambers on both of my carbs. I just need some advice on what to do. I can find new plastic replacements for 85 bucks a piece. I was told that I should go with used metal ones instead. I can find sets of older carbs with metal bowls for around 50 bucks a pair. Will my high speed orifaces screw out of my old bowls and right into the metal ones? Will everything switch over, like the gaskets and floats? I read somewhere about having to change over the intermediate jets to a different size due to a difference in the metal vs the plastic bowls. I am not sure what to believe or which route to pursue. Thanks in advance for your advice.
