dukboat
- Dec 13, 2007
- 52
Hello, I have a 1951 Evinrude 3.3 4425 Sportwin that has a carb problem. This is the one without a choke, it has a primer button. I push the primer button a few times and it fires up with one pull and runs for a few seconds, if I keep pushing the primer button it will keep running. Does anyone make a carb rebuild kit for this motor? The motor has been used very little and looks like new inside and out. It has the original plug wrench, spare shear pins and cotter pin and a spare recoil spring. Would it be ok to mix a little gumout in the fuel mixture and pump the primer to try and clean ot the carb? I don't want to take the carb apart unless I can find gaskets for it. Thanks for your help.
