Re: 78 ? Johnson 25 hp coil replacement... GOT ER RUNNING
OK it's September and Febuary was my last post. (Finally saved the money for parts).
I can now say that I am a proud owner of a 1978 Johnson 25 hp motor that is back up and running.. Thanks to this forum and all its knowledge. And my determination to fix it !
Run Down in order of what I did to her.
1. Replaced power pack (was the first attempt, still died)
2. Replaced water pump impeller (thinking it was over heating)
3. Took carberator off cleaned it ( did not use a kit)
4. Saved money and got on "iboats forum" day in and day out checking out all threads as to why it would die on me after running WOT .
5. Ordered parts... (A),Sensor assy. #0583387 (B), Coil and Lamination assy # 0582059 (C), Fuel pump kit #393103 (D), Carb kit #0396701
6. Pulled fly wheel and put it all together, again using "iboats forum"
7. Dropped her in a trash can full of water, third pull fired right up... YES!!
8. Put her in the water for a good test run.. took a few more pulls than three this time . was getting blisters from the rope pullin, finally she fired up.
9. Crusied around put her back into WOT ran great. I was GRINNIN !! All of a sudden SHE DIED ???? I was thinking WT #%%@$
10. My buddy could see I was getting ready to throw it in the bay, so he said let me look at it....... Now i'm no mechanic but he got back there and SAID.. Oh your throttle arm (small metal arm that adjust your throttle as you give it gas) has fallen off your carb thats probably been your problem the whole time... "I'm like, YOU HAVE GOT TO BE FRIGGIN KIDDIN ME".
Well needless to say if that was the problem or not at least I have pretty much rebuilt the motor so she should be good to go for my Grandkids to enjoy on down the road.
By the way I never did replace the coils as my original post question was about. LOL
