eandkatthebeach
- May 27, 2008
- 45
Hi guys - I'm the one replacing the forward and pinion gear as well as clutch dog for the subject engine. I finally got my parts in the mails, and I have a couple questions: In order to re-instal the drive shaft I have to hold the roller bearing in place - the manual says to use "OMC Needle Bearing Assembly Grease", there aren't many boating stores in No. Jersey, so I asked my local West Marine guys if they had any or a substitute I could use. They weren't even sure what I was asking for and offered my trailer grease..... I was going to just try to use the lower gear case lube to hold them in, but that's a hit/miss affair. Any suggestions on what else I can use - e.g. vaseline or O-Ring lube???
Second - I need to put the new Pinion gear on the end of the driveshaft once it's in - do I need to support the shaft somehow to press the new pinion gear on the driveshaft - or will just getting it to hold on there and putting the pinion nut on get me there?
Third - any trick to get the pinion nut back on the driveshaft?? I have a long 7/8th inch wrench I used to remove it, so was thinking I could maybe tape the nut into the wrench - or maybe use a magnet on the wrench to hold the nut till I get it back on?? Any ideas or correct direction would be helpful - I don't have any special OMC tools, just using common sense so far.
Thanks again for all your help and ideas in the process of tearing it down
