hgvoce
- Dec 1, 2011
- 29
I have a 2000 Johnson 200hp low time outboard that is hard to crank when sitting for say a week or two. Once I get it to crank it will fire instantly and runs great, it is just that initial crankin at the ramp that seems to take forever.
Here is what I do .....
prime fuel bulb to firm
turn key to, ignition ON, get the 4 lights / beep
push the key in, here the click, turn key one more position to engage the starter while holding the key in
Do this till it fires, which is normally a fire and die for several times. Will not take gas at first, just dies.
very cold day, been sitting for 2 weeks, did not think it was going to crank, finally did, (luckly no one else was wanting to put in) to forever. Afraid for the starter, although I do soin the engine in short cycles as to not over heat the starter.
So are you suppose to crank this cold beast?
