Re: 1968 55 hp Johnson - Can I easily Install Power Trim/Tilt?
Thanks for the info. $670? Yeah that is steep, though Ill consider it (I have alot invested in this motor).
A second question, I have this motor connected to the more modern "push-pull" steering - if thats what you call it, but the trouble is I cannot tilt the motor all the way up because the transom bracket (which has the tube for the push-pull cable actually HITS the steering arm when the motor is tilted up. Is there a conversion kit that others have used which works well with this motor??
Thanks alot!
