fishing_Rick
- Feb 14, 2012
- 2
I have a 75 HP Johnson that I have rebuilt the carbs changed all fuel lines rebuilt fuel pump, changed spark plugs, checked timiming and it seems OK, looked at all wiring, adjusted carb linkage, had to change speed and shifter cables. I am not sure what to check next. It idles and starts OK but when I try to increase speed it either hesitates or dies. But when I goose the throttle control I can get it to go like a bat out of hello and will cotinue until I throttle Down.
Can someone guess what I might have done wrong or what might be the problem?
