1979 70 hp evinrude has loss of power. "mechanic" has rebuilt carbs, set timing, run compression(125+/- all three). He thought that would solve problem but did not. He now thinks exhaust leak from gasket where Powerhead mounts lower unit is the culprit. The motor runs great on muffs and in water on low speed, but when throttled up to full speed the engine begins to bog down and never makes it past half throttle. I can remove motor cover and throttle up and can get a little more power and barely plane out the 15' fiberglass runabout.
I do see some exhuast smoke coming from that area. Could that gasket be the problem? If so how difficult is that to replace. I have moderate mechanical skills and think I can remove Powerhead and do the job myself.
