Re: reed valves
Ive got two engines. Ones a 81 vintage johnson 90 that will buzz right up to 5800 with a 19 pitch and hit 51 mph. Great hole shot. Been with it since day one. 1 5/16" carbs, 140 heads etc. 51 mph with a checkmate enticer. Great running engine that I will run for a few months and pull as a complete spare when the new 140 is built.
The other engines a 140 I'm building from a core with squared ports, 1 3/8" carbs , high compression heads, bubble back etc that I want to run up to 6500 ish. I want to push my boat into the 60's
Question is I have a set of Boyesens and a set of CC sport reeds. Which reed would you use in which engine?
