I have a 1994 20 ft Lowes pontoon boat with a 1994 50 HP Evinrude that will run full power then cut out and run only at half power and idle like crud and the performance would never improve until I would bring the boat home. Using carb cleaner and low pressure compressed air I would clear out the lines. The next trip to the lake the engine would run flawlessly for a day then the next trip out the issue would come back. Last summer before the lake season I have rebuilt both carbs, replaced all fuel lines, spark plugs, spark plug wires, ignition coil, fuel filter, and have added an extra in line fuel filter. Now the boat will run at half power for about the first 20 min. of the day then start jumping until finally clean up and run great. My thoughts and past expierence with engines that electricaly things go from good to bad as the engine heats up, not bad to good. This has me stumped and very aggrivated with it. I'm open to all suggestions.
thanks
thanks
