Re: 1971 johnson 4hp cowl gasket problem
Hi there TN-25, really appreciate u taking the time to upload the photos and respond to my post. My cowl did have several holes around the perimeter of it, when i restored the cowl it was stripped down to bare fiberglass ,and like a dope:facepalm:, i filled the holes with fiber glass filler before i primed it, (i jazzed it up a bit by upgrading the color from white to Duponts ford pearlescent white , new decals ,and then cleared over , wet sand and then polished),had to be done
The gasket sat in the groove ok when i placed the gasket around the pan by itself , but i noticed in the corners had no gap, so if i placed the cowl onto the gasket that is already sitting in the pan groove it would be a no go.So i put gasket on cowl and cut notches in each corner on the inside so it wouldnt bind,didnt see any way around it, so im assuming a variation of that was done in the factory. the staples make sense due to the fact that the gasket tends to pull away from the cowl in areas likely not helping my fit.One thing i tried was holding the gasket in place, putting the cowl on the motor and tapped the cowl down so it would sit in its groove , i got it to go on somewhat and pulled the lever to lock it down ,but as i did this it was really tight and the area where the hook is on the inside of the cowl actually caused the fiberglass to bow inward when locked down, shouldnt be that tight.
So im really wondering if it is correct , i did email the guy i purchased from before i ordered it to confirm right part, and concluded this was the part, we both agreed and i ordered it. The only thing is that off the the cowl it fits well,may just require more fine trimming in areas and definetly staples as you said, just need to find a way to staple without worrying about cracking the 31 year old fiberglass, probably more forgiving in 1971. So i guess i need to secure it properly, doesnt fit nearly as snug against the cowl like Photo #3,which is my motor exactly.Securing properly to cowl will be my next step, as well as looking for areas to trim,also an image of the front of a cowl where the tang is that slides into the notch in the pan(front),may also not be trimmed right.
Once again thanks for the photos and the ideas/info, really appreciate it,any other ideas that may come to mind fire them my way . Thanks again,Stickler.
