Re: evinrude 60hp V-4 specs????
A '64 brochure lists the 60hp@4500rpm. 70.7cuin, 3" bore, 2-1/2" stroke. gear ratio: 20:23. There were a number of different props available so speed would vary depending on the prop used. Max rpm is listed as a range of 4000-5000.
Verne
