Hello. I'm having problems with my 200hp looper & was hoping someone has a logical resolution for it. First off the oil injection has been bypassed & I'm running a 50:1 mix.
Heres what I know: The engine starts right up, Idles nice and runs great all the way to the red line on plane. But... now the catch... The engine has to be trimmed up enough so it can breathe. which sucks for a multitude of reasons.
The problem comes in with the engine trimmed down. it will start but imediatly die, or will bog out completely if you try to put it on plane. Yes the engine does sit low in the water. the exhaust reliefs are about 1 1/2"above the water line.
I read a post about johnson putting 1987 carbs on 1988 motors to cure this but what if anything can I do to cure this problem on a 1987?
Any input would be greatly apreciated!!!
oh ya! its mounted on a 1988 22' concord Magnum.
