1925-26 Johnson A25 2 hp, need working coil
Status
Not open for further replies.
willocreek1202
I am restoring a 1925/26 Johnson A 25 and I am looking for a working coil and capacitor.
Thanks.
HighTrim
Re: 1925-26 Johnson A25 2 hp, need working coil
Try Doug Penn
douglas.penn@gmail.com
If he does not have one, he may be able to point you in the right direction. Short of that, post a wanted ad in the webvertize of aomci.org
nwcove
doug penn is the best bet, but would a coil ( if it was ok) from this motor ( 1928) work ? its just a wall hanger, so if someone could use non visible parts.....the cost of shipping works.
HighTrim
What model number is that nwcove, I cannot read it in the pic? Would first have to verify that it is hot though.
They can also be rewound, PM if you are interested in that and Ill send you the details.
HighTrim
...and by the way, the A25 uses a .12 microfarad condensor for your search.
willocreek1202
I would like to have the details on rewinding.
Thanks Chris.
nwcove
the spot on the sheave where the model number would normally be is blank. i do have another one .....oa-55 ( or Qa-55) 1932 i believe.
HighTrim
It looks exactly like my 1928 2.5hp AC-35, or A-35 as it no longer has the canoe bracket. Im willing to bet that is what yours is.
I also have the Canadian cousin to your OA55, which is an OK15, made in Canada. Yours is a 3hp whereas mine is an 8hp.
Those 2 motors share condensors/coils, and I believe the A25 shares them as well, but would have to look into my manuals.
nwcove
those are nice looking old motors, too bad mine are just wall hangers! ( the 1928 has a hole rusted through the outer water jacket, but still has compression, the 1932 has compression, but is missing its original tank.) both are peterboro motors.
HighTrim
Just barn finds, a little banged up but Ill get around to them one day. They are in a long line ;)
nwcove
know what ya mean bout getting around to it.....wife actually found me a " round, to it" at a craft sale! so i can no longer say, i will do that when i get around to it, cuz now i have one! :facepalm: ( wish i would have thought of cutting a piece of pine in a circle, stenciling " round to it" on it, varnishing it , and selling it to wives! lol )
BIGhunk
new member as of today, did you find a coil?, i need one also, can you point me in the right direction
GA_Boater
This thread is almost 6 years old and I'm sure the OP found a coil. Look for replies in you new new thread after members see it. Thanks.
Closed.
Status
