Re: 1954 evinrude fleetwin 7.5 gear oil capacity
When you take the water pump assembly out, you want to make sure that you don't remove the upper bearing housing. There is a gasket under that and if you do happen to break it loose, then you will need to replace the gasket there. As far as the impeller housing, no, there isn't any gaskets there. When you put it back together though, you can put a small film of sealer on the bottom of the impeller housing, to seal things up there.
