Dabbler_E
- Apr 20, 2009
- 338
Hi All,
Sorry for the rant nature of this post, but yesterday was a pretty difficult day. Ultimately, I'm pretty sure that the fix will involve a complete carb teardown, but any more specific pointers would be helpful.
This is a motor I got on eBay last year as a 9.9 and installed 15 hp carbs (as well as replacing points & coils, replacing fuel lines, and adding a telltale -- see my "1980 14' Lowe Superior V Restore/Repurpose" thread in linked in my signature).
Symptoms: starts easily cold, and initially idles OK. Then after running for a while and shutting down for an hour or so it becomes very cantankerous, difficult to start, and really does not want to idle without some choke. That makes it really difficult to get into gear at reasonably low rpm without stalling -- I basically have to pop in and out of forward gear and fiddle with the choke until the boat gets some forward momentum. This problem presented during a duck hunt about a month ago, but it was only a very short run so it wasn't a big deal. I thought the problem was a loose low-speed idle knob (which tended to drift out of the proper position and toward "lean") -- fixed that. Motor started easily at home, and would idle fine in a barrel of water for extended periods, lulling me into that dreaded false sense of security.
The misbehavior came back and presented a huge problem while out duck hunting with a couple friends yesterday on a big lake in 15-20 kt winds with temperatures dropping below freezing. Again, the boat performed fine while motoring in and idling around while putting out decoys. About 2 hrs later, while going out to retrieve a drifting decoy, the motor stalled when I throttled back and I had a real hard time getting it started again, the 14-ft semi V wallowing about in 3 ft swells (which, fortunately, it handled with aplomb). I shuttled one person back to the dock and the motor stalled when throttling down for the no-wake zone -- took many pulls to get started (exacerbated because the recoil spring decided not to take up more than about 8 inches of the pull cord). Went back to get the other hunter and decoys, and used a trolling motor to maneuver around. Fired up the motor the head back in, but we wanted to retrieve a drifting decoy out of open water. You guessed it -- stalled when I throttled down, and really couldn't get it back started. Pullcord broke, and went to the old school cord wound around the flywheel, still couldn't get it going. Used trolling motor to cross open water (mostly cross wind) toward the lee and ultimately to the cove with the boat ramp. About 100 yards from the dock (after running the trolling motor on high for probably 20 minutes straight, covering about 1/2 mile), trolling motor quits, 10 ga wires smoking (not fused -- the kind you clamp direct to the battery terminals). Disconnected the wires quickly, and dropped them in the lake to cool.
My companion went to plan C and started paddling, which basically just kept us in place because the wind had now shifted to being more against us, while I tried to get the motor started. Finally got started and successfully in gear, motored to the ramp. And, no, we didn't get any ducks.
Practically everything that could have gone wrong did go wrong, except that (A) nobody went in the drink and (B) the boat never took on water, (C) the wiring did not actually catch fire, (D) the motor did ultimately work, and (E) we did ultimately make it to the ramp.
Needless to say I NEVER want a repeat of this experience. Like I stated at the top, this probably needs a complete carb tear down (I replaced all the easy stuff in the fall, but never popped the core plugs & cleaned out those passages manually), but if any of you have more specific suggestions, that would be great.
Here are some things I learned:
A) always have starting fluid on hand. I know that it is frowned upon here due to lack of lubrication (and the problem should be fixed at its source rather than relying on a can), but in a hairy situation I want that motor to START.
B) 8 ga or even 6 ga wire on the trolling motor, with fuse or circuit breaker.
C) NEVER trust performance in a barrel; if you think you've fixed a problem and anticipate going out in difficult conditions, do a sea trial under better conditions first.
Thanks for putting up with this rant.
E
E
