Hi, i recently bought my first boat with a 70 hp johnson, runs great on the hose, and under idle. But when i tried to put load on it at the dock, it would cut out after putting the throttle about 1/2 way. Once i ran it on the water, the problem seemed to stop and it ran fine. Then i pulled it off plane, and it did the same thing!!!! after struggling with this for about 15 minutes,the boat finally seemed to jump into higher rpm's, and ran fine, i rebuilt the carbs, replaced the gas lines, and put new spark plugs in, still the problem persisted. Also, pushing the choke seemed to have no affect, any help would be greatly appreciated!
