I have a 1992 25hp johnson that i am trying to change the water pump on.
I have it down to the shift rod and have unscrewed the top fitting from the bottom fitting.
I am trying to slide the top fitting up to expose the keeper. This fitting does not move.
This is a newly acquired motor and has been run in salt water.
Thanks in advance for your help.
