stretch751
- May 17, 2010
- 14
The rod connector does not hold. I can see it slip in the side window.It occasionally will slip out of gear at high speed. All of the lower unit parts, gears, dogs, simply everything are brand new. It is as tight as a brass connector can handle so I would like to replace it but can not find the part number or a supplier. Thank you
