Re: would a johnson 1978 200 hp tilt trim setup work on a 1976 johnson 200 hp motor
Until emdsapmgr gets back to you, let me jump in and say that you should stop operating the PTT while you have it connected as you do right now. You have your "up" (blue/white + blue) wires direct connected at the terminal strip. The trim motor draws up to 44 amps going up. If you keep running that high amperage through your trim switch, you're going to melt the plastic casing on it. Those little jewels are $100+.
Remember: green grass = down; blue sky = up... Your green wires run the trim motor down, your blue wires run it up.
-Your green/white from switch direct connects to green from trim motor at the terminal strip
-Your blue/white from switch connects to one of the small terminals on the solenoid
-Your blue from trim motor connects to one of the large terminals on the solenoid
-Your battery connects to the other large terminal on the solenoid
-You mentioned an automotive solenoid, if it's a grounded base type, connect ground wire from battery and ground wire from motor to the base of the solenoid. If it's not a grounded base, connect them to the small ground terminal on the solenoid.
couple of diagrams/pics...
Trim switch basics (current draws based on Prestolite motor)
How to wire Ford solenoid to replace PTT solenoid
caveat: The '78 PTT originally came with a 3 wire motor (blue,green & black). If over the years, that motor failed, and someone replaced it with a 2 wire motor (blue & green), disregard everything above.
You'll have to go to a double relay wiring system.
