Hello all,
I've got an electrical issue on my '60 75hp. No spark. It was running poorly at high RPM (never sustaining full RPM) so I opted to redo the electrical after a total carb overhaul proved fruitless. When I opened the distributor, I found pieces if the spring that contacts the coil everywhere inside, and the clips that hold the coil in place were shattered.
I've replaced the coil(and the clips that hold it steady), plugs, wires, points & condenser.
Now I get no spark.
Great repair huh?
When I put the meter on the coil Hi-voltage output (the little brass nub on the top) and spin the shaft I get good readings. But when I put the cap on, I get nothing from the plug wires.
With the cap off I connected a patch wire from the brass nub on the coil to the little spring on the inside of the distrib cap that usually contacts the nub, I get a strong reading at the spring.
With the patch wire still in place, I looked for a reading at one of the 4 points inside the cap where the rotor passes, and I get almost nothing.
I assume the hi voltage from the coil feeds to the positive 2 of the 4 points via a wire molded inside the cap?
I've had no experience to this point with magneto style distributors, and this befuddles me, but I fancy myself handy enough to fix the issue.
Can the cap just suddenly go bad?
Is it wired internally, molded within the cap?
Any help would be appreciated.
Thanks all,
Bill
Now I get no spark.
Great repair huh?
Thanks all,
Bill
