muskieman1
- Dec 23, 2011
- 2
Just purchased a boat with a 1992 Johnson V6 150 hp silver select series motor. Took it too my local marine mechanic for a quick once over and he indicated that it had good compression, but the power pack was not operating on 3 cylinders. Had it replaced and it ran perfectly. Took it on my first fishing trip and for the first 2 days in ran perfectly. On the last day the motor briefly (1-2 sec) powered down just after getting on plan. It happened several more time before we arrived at our spot and when decided to leave the motor would only operate at an idling speed and would bog down and shut off if you gave it gas. If you pulled it out of gear and hit the throttle the motor ran fine, but again would shut down when you put it in gear. Went back to the mechanic and he determined that the new powerpack was again not operating on the same 3 cylinders. The powerpack will be covered under warranty and my mechanic indicated that all specs for the motor were in order when he installed the original, but I?m a little concerned it may happen again. My question for the group is could there be an issue in the motor that is not being detected in his diagnostic that could cause the power pack to fail? He did make 1 comment that stuck in my mind and that is that after installing the power pack he indicated that the volts were higher on 1 bank that the other, but the lower volt readings still meet the minimum requirements to operate correctly. He should be installing the new unit next week so any input would be helpful.
Thanks for the help!
