jeffrey9567
- Jan 5, 2011
- 10
I posted this same problem before. 1976 9.9 Johnson will start cutting out(missing) after running at full throttle for a couple minutes. Everybody seemed to lean toward air leak in fuel system . I replaced bulb, hoses , and clamps. Really thought that was the problem because the bulb never got hard that quick. Still does it though. So when it started doing it I tried cracking the gas cap a little (didn't work). Then tried pumping the bulb ( no good). Played with the lean/rich adjustment both ways (nope). As a crazy last resort I idled down , reached back and took the motor cover off. I then opened it up to full throttle , it sputtered twice and took off like nothing was wrong. What the hell is going on. The outside temp was about 40 degrees. Could one of the coils be malfuctioning when its hot and cooled off when the air hit it.? I'm lost . Ready to use it for an anchor.
