Re: Will a tilt and trim unit from a mid 80s 150hp Johnson fit a 1977 140 hp Johnson?
Yes, BUT check the wiring on the electric motor. The 1977 electric motor incorporated 3 wires, the later model PTT you're asking about might be the two wire type.
The 3 wire type uses a solenoid for the up mode and direct wiring for the down mode. The two wire type uses the dual relay setup for both modes.
