Can anyone advise me if the Lower motor covers are interchangable between the 73-77 motor style and the 79- 95 motor style? I picked up a newly rebuilt 1985 Johnson 115 that took a fall from a display stand and cracked the lower motor cover. The Upper cowl will still fit on it and latch, but not correctly. I have 2 lower motor covers from 73 - 77 motors(a 73 and a 75 I believe). Will these fit the 85 motor? I looked at the parts diagrams for several years and they have different parts numbers for each year I looked at. These are all crossflows. I can not tell to look at them if there are any differences from the diagrams.
Secondly, what do you need to remove to replace the lower motor cover? I have a manual, but it advises to pretty much strip the powerhead including the carbs and intake. This seems like overkill to me just to lift the powerhead up a few inches to clear the lower cover and then swap them out. Does anyone have any tips on replacing the pan? I have swapped complete powerheads on different lowers units in the past with out stripping parts off, but I would rather ask for advise before I end up working harder on this than I need too. Thanks in advance for any help, hopefully this will be my winter project.
