Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
1968 johnson 3hp water pump replacement
  • 1968 johnson 3hp water pump replacement
    Hi, can someone walk me through the replacement procedure for the water pump impellor on a 2 cylinder johnson 3hp twin, 1968 model? I have done this on newer motors but I am looking for a step by step procedure (this is a direct drive motor) (no forward or reverse shift) thanks in advance.
    Re: 1968 johnson 3hp water pump replacement
    Remove the 4 bolts that secure the lower unit to the mid section and then wiggle it free. That's it. Once you get the lower unit off, you'll see a housing with 4 screws on it and the impeller is under there.
    Admiral Zephyr
    1941 Johnson HD-20 (in restoration)
    1947 Sea King 5hp
    1948 Evinrude Sportsman
    1951 Evinrude Fastwin
    1955 Johnson CD-12
    1955 Johnson RD-17
    1955 Evinrude Big Twin
    1956 Johnson RD-18
    1957 Evinrude Big Twin
    1958 Evinrude Fisherman
    1958 Johnson FDE-12
    1959 Johnson RDSL-21B
    1974 Tanaka 1hp (screamin' drink mixer )
    • #3
      so, being direct drive, there is no shift linkage to deal with. iboats lists an impellor kit and a water pump kit with different part #'s. what do you think i will need as far as parts go?
      • #4
        Take it apart and see how the housing and plate look. If the housing is not corroded/cracked and the plate is flat/smooth and not rusted, then you probably only need the impeller. Try not to pull the driveshaft out of the gearcase when you do the job, as it can be frustrating trying to mesh it back into the pinion gear splines.
        • #5
          Lindy speaks truth! I had to drain/disassemble one as I could not get it re-aligned. The good part is that there is nothing in this life simpler than a 3hp gearcase!
          author unknown: It's almost beyond the point of bearable how torturous it is to try to have any dignity in being a Vikings fan..
          • #6
            Yea, you don't want to pull the drive shaft. I have on one, but fortunately, I lined things back up easily enough and didn't have an issue, but from what I see, the pinion gear will be able to move around feely, if the drive shaft comes out.
            Admiral Zephyr
            1947 Sea King 5hp
            1955 Johnson CD-12
            1955 Johnson RD-17
            1956 Johnson RD-18
            1958 Johnson FDE-12
            • #7
              If that drive shaft does come out.....a little trick I heard about, is to hold onto it with the prop shaft pointing down. Front of gearcase pointing UP so pinion gear will fall back down into place. Turn prop shaft back and forth a tiny bit while dropping drive shaft back into the pinion gear.
              It is a bit tedious, be it should go. Quicker than taking it all apart.
              Chris
              Top Secret Files:
              http://forums.iboats.com/showthread.php?t=299680
              PROUD NOW OWNER OF SITE DEDICATED TO ANTIQUE AND VINTAGE OUTBOARD
