Reassembling my AD10M and the Johnson parts catalog shows two parts that I have forgotten which way they go in. It is in the Gearcase Assembly Group, part numbers 5 and 6. The diagram is a little fuzzy for me to see. Does part number 6 go in cup up or cup down? I am assuming that it goes cup up because there is nothing under it except for a pin through the driveshaft. The other part which is number 5 is a spring. I have forgotten which end fits into part number 4. One end is flattened and the other end is not.
Got some good eye balls around that can help with this.
Thank you.
Thank you.
