'81 Evinrude 235 may need powerhead
dannycantu
I have a johnson 235,1981. With blown arm and piston on The center starbird side. i tried to repair and remove the sleve i think i need a new powerhead block.
QC
Re: '81 Evinrude 235 may need powerhead
Welcome aboard danny!! Please take a quick read of our rules. We don't allow any soliciting here, but we will certainly try and help you diagnose any issues you have.
I moved this to your won thread so that you can get focus and the other thread starter's focus stays intact. Good luck!!
emdsapmgr
When you go looking for a new block, make sure you ask for and get the right block. keep in mind that you have the 160 cubic inch 235 block. The early blocks were 149 cubic inch and your internals/heads won't fit on these.
Faztbullet
What did you damage|??? Post a picture as replacing sleeve is really not a DIY repair. Depending on damage it can be repaired, the only blocks I cant repair are the ones with damage thru crankcase flange or certain area into internal water passages.
