dannycantu
- Dec 10, 2011
- 1
I have a johnson 235,1981. With blown arm and piston on The center starbird side. i tried to repair and remove the sleve i think i need a new powerhead block.
What did you damage|??? Post a picture as replacing sleeve is really not a DIY repair. Depending on damage it can be repaired, the only blocks I cant repair are the ones with damage thru crankcase flange or certain area into internal water passages.i tried to repair and remove the sleve
