Re: Why delete the VRO ?
I had VRO on a 1988 70. It failed once: ran out of oil (daughter using it, but I take the blame) and no alarm. We rebuilt and ran it for several more years w/out a problem, then I replaced the motor for other reasons with a 1986 70 that the VRO was disconnected. I feel a lot more comfortable without it, and I use the boat alone in remote areas a lot.
I also almost lost the rebuilt motor when I found the oil hose was cut.
IOW I do not trust the system, especially the alarms, on an old motor, but I am OK with it on my 2003 Yam.
The VRO is very convenient and generally reliable for the casual recreational boater. Commercial boaters see them as too risky and they don't mind mixing, so they are the first to disconnect or buy a commercial grade motor without it.
I think Yamaha solved the biggest risk by putting a decent sized gravity fed oil reservoir inside the motor cowl, to back up its "VRO" from the tank. But you are still riding on the strength of the alarm.
I have an older Yam 50 where you pour the oil in the top of the motor, no seperate tank. It's a good idea but a PITA in design.
All a matter of preference based on confidence in your equipment, and the risk if it fails.
BTW I never heard about not running gas out and we did it some, but not often, with the 1988 70, no problem.
