Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
1990 Johnson 60 HP VRO Power Head Rebuild - Torque Specs ?
  • 1990 Johnson 60 HP VRO Power Head Rebuild - Torque Specs ?
    Anyone here know the torque specs for connecting rod bolts, crank case and head bolts ?
    Do I need loctite on anything ?
    And do you use gasket sealer on new head gasket or just bolt the new one on ?
    Thanks
    Shawn
    Re: 1990 Johnson 60 HP VRO Power Head Rebuild - Torque Specs ?
    You should get a Factory Service Manual for a job like this. It shows the correct procedures for tear down and reassembly, torque specs and what sealers to use.
    • #3
      Too late ..I already rebuilt it and put it back together.. I used a book from the library ....found torque specs in there.
      I just figured someone would know the answer about using anything on the new head gasket.. ?
      • #4
        Dry head gasket.
        Help somebody every day, if you can.
        • #5
          If the gasket says on it " use no sealer " then it goes on dry. Otherwise you should use OMC gasket sealing compond.
          Back to Top
