Re: 1950 evinrude
That model has the earlier style ignition system in it. You may not need coils, unless they're damaged. On those older ignition systems, the coils ususally hold up better than the later universal type. If you replace the spark plug leads and condensors first, you might find the coils come back to life and also clean and re-gap your points. If these tricks don't work, then try Sea-Way Marine, in Seattle, or Engine Blade and Prop.
