Found out my head gasket is blown. Got the head off, gasket came off easily, cleaned the surfaces with a plastic scraper. I will check the head on a glass plated and have it milled if necessary. But on the block side there is a pattern from the gasket in the metal of the surface. I really dont want to take the block off also, could I use emery cloth or sand paper to smoothe out the block surface? I was thinking i could use some flat bar with sand paper on it. Is this a good idea or no? Also should I do the same on the other cylinder head to keep compressions the same?
