Mullerhawk
- Aug 2, 2011
- 37
Hi,
I have got my hands on a couple of Evinrude/Johnsson 1985 15HP engines that I am renovating. This particular Evinrude was suffering from a dirty carburator + sporadic cooling. I have changed the impeller and renovated the carb with success. The engine idles perfect and starts on a couple of pulls without hesitation, and cooling works as it should now.
But from the upper exhaust relife port it sprays a little bit of water which seems to be normal looking from reading at this site. But what is strange is that I get alot of exhaust/white smoke fumes coming up from the water - but not from the upper exhaust port. If I rev the engine it seems to be more (have only tested the engine in a barrell after going through it). I suspected it might be leakage from the head, but since the spark plugs seems normal I am wondering if this is only due to the engine not beeing run for several years.
No visible signs is seen under the cowling, and the engine sounds normal. If it is not the head gasket (have not checked compression yet!), could it be something wrong with the exhaust port gaskets (is water flowing though here?!) ??
Thankful for your input,
// Mike
// Mike
