Have a 2001 Johnson 50 HP just started having problems recently. I took the pontoon out and ran compression check have 120 in both cylinders. Clean new fuel filter. I switched spark plug cables around. I am not getting "spark" to the top cylinder regardless of which spark plug wire I tried so it has to be upline. Any help would be appreciated. New to the forum. Thanks!
