Re: HELP!!1952 Evinrude tiller bracket
Well It's alive!!!! Clean and set the points, coils look good. set the plug gaps. Have good fire. Oh boy!!! I hooked the carb up to a gas line from another outboard i have and shot some fuel to it. after a little pulling it came to life. sound like the rods were brock. So i put oil in both ends in the carb and plugs. it started a little and smoked like a train. I had to work 12's the past week so it set. Started it up this morning and the knocking was gone. I mess with the low speed needle a little and got her to run. Gas tank was really bad, cleaned it out . Cleaned the fuel filter that go's in the bottom of the tank, then i cleaned it again and again. mixed up a good 24:1 fuel mix, put it in and she fired up.run good sounded go. I guess i did not need that powerhead i got of ebay.. oh well. i run it about 20 mins and it stoped pumping water. got a impeller of ebay too.
