Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Twisted off bolt head -- now what?
  • Twisted off bolt head -- now what?
    This is the extension piece for a 1970 33hp Evinrude. I was lucky that the broken off bolt head did not prevent me from taking off the extension. Now that I have it accessible for further surgery to remove the remaining piece of the bolt, I am concerned that if I just grab a hold of it with my vice grips, it may just break off again. I'm sure this situation has come up before. What is the recommendation? The paint job is decent on this motor, so I don't want to ruin it by burning off the paint with a flame. So I assume plenty of WD-40 is the best course of action? BTW all the other bolts came off fairly easily.
    Click image for larger version
    Dozen or so 4hp to 33hp Evinrudes 1963 thru 1978 and 1 Mercury 1977
    16' MirroCraft
    Re: Twisted off bolt head -- now what?
    I would get an oxy/celylene torch and concentrate the heat on the bolt only. Use a small fusing tip, so it doesn't hit the aluminum. Get that baby glowing hot, then let it cool down. Once it's cool, you should be able to get a vice grip on the stud and remove it. You'll be able to tell, whether it's going to come out or twist off. If it feels like it isn't going to come out, then repeat the heat up process.
    Admiral Zephyr
    1941 Johnson HD-20 (in restoration)
    1947 Sea King 5hp
    1948 Evinrude Sportsman
    1951 Evinrude Fastwin
    1955 Johnson CD-12
    1955 Johnson RD-17
    1955 Evinrude Big Twin
    1956 Johnson RD-18
    1957 Evinrude Big Twin
    1958 Evinrude Fisherman
    1958 Johnson FDE-12
    1959 Johnson RDSL-21B
    1974 Tanaka 1hp (screamin' drink mixer )
    • #3
      I remember those 33 hp Evinrudes. Popular engine back in the day.
      If that where mine to fix (i.e. extract the remains of the bolt), I would . . .
      - Soak some PB Blaster or Liquid Wrench into it for a day or so.
      - Heat the surrounding material with a propane torch while I tried to back the bolt out with Vice Grips.
      You may want to try a couple of heating/cooling cycles on the surrounding material before you go with the vice grips.
      Best regards, Ted . . . . Cape Cod, MA
      Formula 330 Sun Sport, O'Day Mariner Sail #3224, Sunfish
      Past Boats: Catalina 22 Sail #10531, Formula 242 Sun Sport
      Twin Mercruiser 7.4 LX MPI (0F802036, 039), Bravo 3's (0F806198, 199), Mercury 7.5 HP (1969), Johnson 4.5 HP (1980)
      My Boating Web Pages: http://www.tpenfield.com
      Member of the Month - February 2013
      • #4
        By heating the bolt you're only expanding it. Heat the area around it. Mix up a 50/50 solution of acetone and atf and try that on it also. Get Mapp gas rather than propane as it gets hotter.
        • #5
          I have propane but no oxy. I'd really prefer not to heat it anyway. I guess I'll just keep spraying on penetrating oil each day until it's time to put it back together (which could easily stretch into many days or even weeks at my pace). Then give it a turn and see what happens.
          16' MirroCraft
          • #6
            Just thought of a great idea: cut a slot with my dremmel in the top of the bolt head and then hit it with my impact driver. I'll give it at least a few days of WD-40 first though.
            16' MirroCraft
            • #7
              Concur with PB Blaster and DO NOT HEAT the bolt. Heating the bolt, as explained, will expand it and make it tighter. You want to expand the hole around the bolt.
              Slotting is a great idea. Been successful in the past.
              Worst case, you may need a carbide drill and an EZ-out.
              J
              • #8
                WD-40 is one of the most ineffective products you can use to break a stuck bolt loose. It has a lot of good uses but not for this job. But, it's your bolt.
                • #9
                  get a stud extractor first, after pb blast soak. Also as last resort use a left hand drill bit, you have a good stem on the stud for a extractor to grab. 5.99 at Harbor Freight or better ones around
                  • #10
                    I've done my share of this and many of the recommendations are good ones, some are not. That's cast aluminum, heat the casting not the bolt.. Good idea=yes. Smack it with your impact driver, Good idea=no.. You'll probably just crack the casting. Use map gas or O/A Good idea=yes. Use PB Blaster Good idea=yes. Left hand drill bit. Good idea=no unless you own stock in the drill bit company it won't get enough bite to turn the bolt. That works on wood screws but not frozen corroded stainless steel bolts in aluminum. Use a bolt extrator or easy out. Good idea=no, if you break it off you can't drill it again.
                    My best luck has been with repeatedly soaking it down with PB blaster for two or three days then heating the casting to about 500 degrees and putting a pair of vice grips on the bolt and working it back and forth just a little at a time until it finally comes free. Go to your local welding supplier to get a heat crayon. Infrared thermometers don't work very well on aluminum. If you can't get vice grips on it then take it to welding shop and have them tack weld a nut on it.
                    • #11
                      Agreed X 2. Especially about the bolt extractors.
                      • #12
                        I heat the housing with propane whenever I have to remove head bolts and they're sticky and it works all the time. Also if one does break I use propane also... It almost always works.
                        Steve.
                        • #13
                          Reguardless of how good you soak it, it won't come out, unless you heat it up. When these bolts get siezed up in the threaded holes, they are in there for good. LOL Even with propane, I usually end up drilling them out. So far, the only heat that has prevented me from drilling them out, has been oxy/celylene, because it's the only thing that can get the bolt red hot enough.
                          Admiral Zephyr
                          1947 Sea King 5hp
                          1955 Johnson CD-12
                          1955 Johnson RD-17
                          1956 Johnson RD-18
                          1958 Johnson FDE-12
                          • #14
                            Find a stainlless nut and thread on or drill out so it goes on stud and arc weld it on .Wait till it cools some while applying penatrating oil not red hot . Work back and forth .
                            • #15
                              Hey, I have an idea . . .
                              How about soaking some PB Blaster and heating the surrounding material?
                              Back to Top
